I am attempting to remove the steering box from my 57 with the body on.
Everything is disconnected and the Pitman arm is still on the box. I'm not sure how to get this out as it has to slide through the dash hole and the firewall. If I could find a magic puller to get the Pitman arm off I might be able to turn the box 180 deg. and slide it inward of the voltage regulator and up but it looks like a long shot. It might also be possible to remove the left engine mounts and radiator shrouding and pull it forward/inward and out with the Pitman arm attached. I know 58/62's are much simpler because the column drops down and is shorter. Has anybody sucessfully done this? Thanks for any help.
John
John
