C-1 Engine mount & fan clutch - NCRS Discussion Boards
  • Joe Fisher
    Can anyone tell me if the front engine mount bracket, 3786779, and fan clutch, 3814560, still available from GM.
    Re: C-1 Engine mount & fan clutch
    Joe -
    I doubt if either one is still available, but Paragon has both reproduction and used original front engine mount brackets, in both versions (with or without the clearance notch for the bypass fitting).
      Joe -
        • August 31, 1999
        • 155
        You can check out the availability from GM at www.gm-restorationparts.com/
          • August 31, 1999
          • 155
