Hi. I saw the post from a few days ago regarding R-12 and I am wondering how conspicuous are the port adapters? From what I've seen on the conversion kits, the adapters look kindof big and ugly. That's the biggest thing holding me back from making the change. I have my system totally apart so now would be the time to do it. Thanks, Brandon
R-12 to 134a Conversion question
Tags: None
- Top
Re: R-12 to 134a Conversion question
As you note, the R-134a ports are different from the original R-12 ones. This is to positively prevent using the wrong refrigerant. You are also supposed to put a conspicuous sticker in the engine compartment advising of the change.
I suppose you could trick this system. That is, keep the R-12 ports and finagle some way to get an R-134a hose to mate with them. Probably need to use a combination of brass fittings.
Where are the high and low ports on your car? Are they obvious? You fill through the low pressure port. That's the only one you would need to change. Yes, the ports are noticeably different, but the point deduction can't be too much.- Top
Dave, I just replaced everything. New evap, new POA, new exp valve, new O-rings, everything. I guess I still need to put a port adapter in, though.- Top
How about R-414b?
I've been reading up on it, since it is recently approved, and the claim is it is R-12 system compatible (no need for seal and oil replacement), and 9% MORE efficient than R-12, not less, like R-134b. Still asking around, the only disadvantage I have seen is it costs about twice as much as R-134b, but at least no conversion is necessary.- Top
How about R-414b?
