60' Fi Distributor cap position - NCRS Discussion Boards
  • Norbert R.
    • March 1, 2002
    • 38
    Help to verify correct Dual window distributor cap position relitive to the #2 plug wire position and the 2 cap hold down screws to the distributor base.
    Any Illustrations?
    Re: 60' Fi Distributor cap position
    Norbert -
    Doesn't your distributor housing have a notch that matches up with a locating rib molded into the base of the cap?
      Norbert -
      • Ed Jennings
        If this is of any help, on my 62 the window roughly underneath #2 is pointed roughly at the rear of the plenum. I haven't tried it, but I believe I can adjust both sets of points from there. I know of no illustration.
        • Ed Jennings
