Noisy T-10 in a 1962 - NCRS Discussion Boards
  • Martin Pfaendler
    My 62 runs fine with a restored T-10. What bothers me is the noise of the gear box when I drive the car. Does anyone have experience with similar problem and how to lower the noise level.
    Thanks, Martin
  • Joe Fisher
    Re: Noisy T-10 in a 1962
    You should not hear any noise from a good T-10. Maybe if you had an M-22 rock crusher.
    Is the noise on acceleration, deceleration, in the lower gears or in fourth?
    • Joe Fisher
      • Martin Pfaendler
        It appears especially in 1st and 2nd gear, and equally when accelerting and decelerating.
        • Martin Pfaendler
            • 15610
            My suspicion is that a bearing is spalling. If the noise decreases from first to third and then virtually disappears in fourth, it's likely a bearing as there is more load on them when torque is transmitted through the countershaft.
            Fourth is direct drive and torque is transmitted directily through the input/mainshaft. The countershaft is just idling and all the bearings have minimum load.
            The T-10s have a bit of gear whine in first through third, but if it is getting noticably louder, it's time to disassemble the box for a checkout. I understand parts are scarce, but I figure the bearings are probably still readily available.
            Similar symptons occured on my SWC at about 40K miles, circa 1966. New bearings did the trick.
              • 15610
              • Martin Pfaendler
                This is very helpful. Thank you Duke. I will take you advice and apply it to the box.
                Martin
                • Martin Pfaendler
                  Martin
