If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I'm sure that this isn't very hard but how does the clock come out of my 66? I now have the instrument cluster out and the heater box. Must the radio be removed? The Service Manual says nothing about clock removal.
It is very simple to remove the clock. If the glove box is out you can reach in and slide the clamps which hold the clock in place off. Sometimes on the back of the clock is a quick nut attached to the back of the clock which will also need to be removed. I assume if the instrument cluster is out the same space works from the opposite side. You can then pull the clock out from the front. Gently because the wires will still be attached. 15 minute project.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
