Here's my problem:
I have a 1965 327 cu. in. 350 HP Corvette. It has a "closed positive" crankcase ventilation system with a metered orifice connection at the Holley 4150 carburetor which goes through a rubber hose to the oil fill tube.
There is no PCV value tn this system and the oil fill tube is closed off with no ventilation. There is also another larger tube (approx. 1") that goes from the rear of the engine block (near the oil pressure line) to the base of the air cleaner which is at
tached to the spark arrestor.
My problem is that the engine is pushing oil up through the spark arrestor into the carburetor and the air cleaner. The car runs excellent, but something is definitely wrong. As an experiment, I wanted to see if the oil was being sucked up, or pushed up through the tube, so I temporiarily closed off the tube at the spark arrestor. Well, it didn't like that at all...there was oil all over the rear of the engine. I checked the metered orifice and it is clean and open.
The only thing I can think of is that there is something missing on the engine side of the tube that is supposed to prevent oil from coming up through the tube. Any help would be greatly appreciated.
John
John
