Under dash insulation - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    There is a blanket of pink fiberglass insulation against the upper firewall inside the car above the heater box. Insulation appears to extend from the pasenger outer side to just beyond the wiper motor on the driver's side. While taking the four hex head screws out that attach the wiper motor to the firewall, some of this insulation was damaged. It actually covers over the motor and it appears my motor was never removed before. This insulation is 35 years old and easily tore as I moved it to get access to the motor screws. I'm assuming that it is there to thermally insulate the passenger compartment from engine heat? Should I be concerned about the insulation tears and try to repack the torn insulation back against the wiper motor after I refurbish it, maybe by using a spray on glue or something.
    Dave Kitch
    NCRS Pittsburgh
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Under dash insulation
    Lets see? 2002 less 35 = 1967. Can I assume we are talking about a 67? At any rate there is no Owens Corning pink fiberglass insulation in a midyear, so I would assume that it is not original stuff.
    • Wayne W.
      • April 30, 1982
      • 3605
      • Dave K.
        • November 1, 1999
        • 951
        Wayne,
        It's a 66 roadster. This insulation appears to be original. It's about 1 in. thick w/o a paper vapor barrier reinforcement.
        DAve K.
        • Dave K.
          • November 1, 1999
          • 951
          Wayne,
          DAve K.
          • Gary S.
            • July 31, 1992
            • 1628
            Dave, when I had occasion to pull the dash on my April built 66 I had brown colored fiberglass(?) insulation that was glued to the firewall. Since I am not anywhere close to being the original owner, I can only state that it APPEARED original. It came out in chunks and appeared very old and beat up.
            Btw, I think Dr. Rebuild sells this stuff in his catalog. I am relying on memory here on that issue.
            Gary
            • Gary S.
              • July 31, 1992
              • 1628
              Gary
              • Dave K.
                • November 1, 1999
                • 951
                Gery/Wayne,
                Wayne may be right. I'm going to check the AIM to see if there is any reference to original insulation installation under dash. My car's insulation was definitely pink, unless I'm color blind!
                Dave Kitch
                • Dave K.
                  • November 1, 1999
                  • 951
                  Gery/Wayne,
                  Dave Kitch
                  • Myles Kukurudz
                    Hi Dave
                    I just replaced the insulation on my 67 and it was like a felt ,yellowish in color and did not cover the wiper motor, It had cut-outs for the mouting screws and was secured by glue
                    Regards Myles
                    • Myles Kukurudz
                      Hi Dave
                      Regards Myles
