Midyear Dash Pads - NCRS Discussion Boards
Midyear Dash Pads
  • Joe C.
    • August 31, 1999
    • 4598
    Midyear Dash Pads
    I removed the dash pads from the dash housing by turning the retainers 1/4 turn. Disassembly was uneventful. All retainer clips look OK, but I wonder if they are meant to be reused, as they must be re-spread upon reassembly. I believe that they were removed and reused at least one additional time in the past. How many times can they be reused before they fail. They are expensive at approx. $3.00 each, and 26 are needed.
    Next, I wiped the dash pads with lacquer thinner to prep prior to dying. One pad remained supple, but the other one became brittle and cracked--don't know why one was affected and not the other. Anyway, I will now replace the pads with a new matched pair. The question is, are there any discernable differences between an original, and an Al Knoch reproduction. Paragon has some very expensive originals, but I wonder if they are worth the money, also, why buy old pads which are likely dried out from age.
    Thanks in advance.
    Joe
  • kenrobb
    Re: Midyear Dash Pads
    Not to stir up any thing, but you might want to look at Corvette America also for dash pads. Believe mine came from them and they look fine. The sun light dries out plastics is the answer to the cracking IMHO. Ken
    • kenrobb
