Engine id-bad
Re: Engine id-bad
There is another method that will show the numbers, if you heat the stamp pad area with a torch (Actelyene) to a red glow and let it cool down, the image of the stamp will appear on the area that was heated. It will not "Raise" to a measureable extent, but the numbers will be clearly visible on the surface of the cooled pad.- Top
Re: Engine id-bad
