As many know, I rebuilding a new 68 frame, the 70-72 did not fit.
So, I found new 68 only spindles, and had the 68 frame and arms dipped.
There back.
How much deduction, if you use the replacement bolt in style balljoints.
uppers and lowers. when getting judged.
Also, I went to the Lima swap and a guy was going to have the factory repo's,
a-arm shaft bushing for sale, he did not. these had longer rubber inserts.
Where can I find them, elsewhere.
Can I send my A-arm to someone to have factory ball joints rivoted in like factory.
also, were the shaft bushings painted, and or what was the factory build paint sequence? What was painted what? shafts, bushings, outter bolt and washer.
I'm going for TOP Flight..
thanks,
jc
There back.
thanks,
jc
