I think I may have a trailing arm bearing that may be going bad. It started as
an intermittant squeak and now sounds like the disk is coming into contact with the brake pads on each revolution of the wheel. The scraping sound is not constant but intermittent. Is there anyone out there that can give me some advice so that I can isolate the cause? I suspect that universal joints could also give the same symptons if failing. If it is a trailing arm bearing failure, I would appreciate recommendations as to where I can get the repair done as I do not have any of the special tooling required. I live in the Indianapolis area if there is any recommended shops here in this area.
Thank You for help!
Frank
66 Coupe
Thank You for help!
Frank
66 Coupe
