Inside Frame, paint spray tip - NCRS Discussion Boards
  • Jeff Chester
    I need to find a flexible tip to paint the inside of my 68 frame.I thought Eastway had one , but can't find one in there book.
    The tip was about 6-8 inches long and was flexible, to shove in the frame holes.
    Any help would be nice and or any other way to paint the inside of the frame.
    It was chemically dipped and is raw steel know...
    Plan on using POR15 rust prevention and then there Chassis coat blk.
    jc
  • Brandon K.
    • April 1, 1997
    • 474
    Re: Inside Frame, paint spray tip
    I had gotten an undercoating sprayer from Eastwood, and sprayed the "waxoyl" into my frame, but I suppose you could also spray paint inside. A word of caution: The sprayer leaked A LOT. I had the liquid wax all over me, but it washed off pretty easily. Not so with paint, esp POR 15. Don't get that stuff on anything you dont want painted for a while to come!
    • Brandon K.
      • April 1, 1997
      • 474
      • Jeff Chester
        yea,
        that POR15 sticks for a while.. I like the warning label.
        "this paint will not come off."
        jc
        • Jeff Chester
          yea,
          jc
          • Chris Burbage
            If you are goung to spray POR15 make sure you have goggles and a good respirator/mask, not the paper type you can buy at the local paint store. POR15 should be treated with utmost care.
            Chris
            • Chris Burbage
              Chris
              • Bryan L.
                • June 30, 1998
                • 397
                When I bought my 67 project car, the frame had been painted (poorly)with POR-15. I have an extreme urge to choke the living crap out of the guy who slopped it on. I will never, ever use that stuff on anything I own. It is a bear to get off and I ended up having to use 36 grit Roloc discs on my hand grinder to get some of it off so I could put DP-90 on it.
                Nasty stuff, no thanks.
                Bryan
                • Bryan L.
                  • June 30, 1998
                  • 397
                  Bryan
                  • Jeff Chester
                    I painted my 72 frame with it, acctually brushed some. I thought it worked great, Loved it , just needed help on the tip. Yes, it sticks....and sticks..
                    thanks,
                    jc
                    • Jeff Chester
                      thanks,
                      jc
