Conv. Top Weatherstripping - NCRS Discussion Boards
  • Richard Pressley
    On a '67 Conv. top there is one piece of weatherstripping that goes along the side above the window, then turns the corner along the front, above the windshield. There are three holes side by side for attaching it to the top. Do all three holes use the push pins or is one of them supposed to be a screw? If so, which hole gets the screw?
  • Jerry M.
    • May 31, 2001
    • 90
    Re: Conv. Top Weatherstripping
    Richard, Just replaced mine last week. The first hole nearest the door window gets a screw the other two get those push pins or whatever they are called. Those will bend really easily if the holes are not lined up just right. Just so happened I had a couple extra.
    • Jerry M.
      • May 31, 2001
      • 90
