Pulley Alignment - NCRS Discussion Boards
Pulley Alignment
  • Joe Fisher
    Pulley Alignment
    I am doing a 283 for my 61. I installed the spacer on the crank and installed the crank balancer, the engine mount with gaskets, the water pump and pulleys.
    The problem is the crank pulley is out too far. So I remove the crank spacer and the pulley is now too far in. I measured the spacer and it is the same thickness as the engine mount.
    Has anyone had this problem before? It seems if I install a spacer 1/2 the thickness of the repo spacer it would be correct, but where do you get one?
  • Ed Jennings
    Re: Pulley Alignment
    Are both your crank and pump pullies original/correct? Might want to verify that first. I guess the balancer itself begs the same question.
    • Ed Jennings
      • Joe Fisher
        Yes, both the crank pulley and water pump pulley are the correct number. I am using a different pump, but checked the height of the flange and they are the same. The crank is a steel one for a 283.
        • Joe Fisher
          • Ed Jennings
            Any possibility the balancer was not fully seated on the first installation? I've never seen this with correctly matched components.
            • Ed Jennings
              • Mike E.
                • February 28, 1975
                • 5134
                Do you have the reinforcement behind the water pump pulley (between the water pump snout and the back of the pulley? When nestled in there, that is approximately half the thickness of the balancer spacer. Just a thought.
                • Mike E.
                  • February 28, 1975
                  • 5134
