1968 SB Hood for my driver - NCRS Discussion Boards
  • james Kekeisen
    Thank you, that will get my search going *NM*
    • james Kekeisen
      • Chuck R.
        • April 30, 1999
        • 1434
        #18
        Re: Thank you, that will get my search going
        Hi Jim:
        I seemed to remember that Chicago Corvette Listed "HOOD inner frame" part # C8461 for 68& 69
        I attempted to call the 1-800 number (800) 872-2446 to see if this was in the realm of what your looking for, but the canned messeage refered me to (708) 458-6577 for technical support
        Of course even if this is the component your looking for, it will mean the arduous process of popping the hood skins apart.
        Keep me in mind on what you find out as I face the same delema.
        Chuck 32205
        • Chuck R.
          • April 30, 1999
          • 1434
          #19
          Hi Jim:
          Chuck 32205
          • Chuck R.
            • April 30, 1999
            • 1434
            #20
            Re: Chicago Corvette Follow Up
            I called Cicago Corvette's tech. line and found out that the inner frame they list is only the inner fiberglass panel.
            No steel work offered.
            Sorry, I tried.
            Chuck
            • Chuck R.
              • April 30, 1999
              • 1434
              #21
              Sorry, I tried.
              Chuck
              • james Kekeisen
                #22
                Thanks for checking. I have fabricated steel plates that insert in the frame rails and bolt thru the fiberglass rails about 3" in front and 6" behind the missing sections. Then I glassed the hole in on top of the steel except where I had welded the mounting nuts (to the back side of the plate to mount the original hinge bolts). Upon fairly close inspection all you can see are the four bolt heads mounted through the frame rail that aren't supposed to be there. In the mean time I'm keeping my eye on ebay.
                Jim
                • james Kekeisen
                  #23
                  Jim
