muncie 4 speed - NCRS Discussion Boards
muncie 4 speed
  • David King
    muncie 4 speed
    I have a 1965 convertable with a non-original 327-300hp motor and am in the process of installing the original rebuilt 327-300hp motor in it. Since my transmission had been jumping out of 2nd when down shifting I thought it was a good time to rebuild the tranny. Upon disassembly I found that the main drive gear had severely eaten away the case at the main drive gear bearing. Normally the case is about 3/8" thick at this point but mine has been "machined" by the drive gear so that it is only 1/4". The transmission is a Muncie 4 speed # 3885010 and the tail shaft is #3857584. I believe my rear axle is a 3.31 or 3.36. I have been told that the transmission is from a 1966 Corvette based on the number. I have also been told that I cannot use this transmission with my car. Any ideas out there? Is it possible that the damage was caused because this transmission is somehow incompatable? I would like to find another case and reuse the guts if possible. Should I forget this idea and find a 1965 vintage tranny? Any help is appreciated.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: muncie 4 speed
    David the your case is replaceable. Visit www.muncie4speed.com and then for some education of Muncie four speeds in Corvettes you could read Alvin Covin's article called Bangin Gears at www.corvettemagazine.com. There are a lot of Muncie four speeds for sale. There are always some listed in the NCRS Driveline by individuals and those who repair and sell them.
    • Jim T.
      • March 1, 1993
      • 5351
      Re: muncie 4 speed
      • Bill Clupper
        Re: muncie 4 speed
        Functionally, your trans is interchangable with the '65 trans, but the '65 used a case with the part number ending in 325. The input and cluster gears are also different from that used in the 010 case. That said, you can either find a proper 65 trans, they are relatively plentiful, or have your case repaired. There is a fellow in New York I believe his name is Steve Becthold how does the work to repair you case, curt if the case is that badly damaged, the Cluster gear is likley damaged also, and you might be better off just replacing the whole trans.
        • Bill Clupper
          Re: muncie 4 speed
          • Larry Low
            Re: muncie 4 speed
            Any Muncie M20,M21,M22 will work in your car. The splines may be different from what you have, ie: possible clutch and yoke change. Your Muncie has a 7/8" cluster shaft. 1966 models up had 1" shaft, so this would make a difference in which case you get if you are swapping your old parts into a new case. There is other differences, example shoulders of syncronizers, if you start swapping parts around. Too many possible parts scenarios to discuss in this format. I sell a detailed Muncie rebuild guide on EBAY called EasyStep that would answer all your questions. Contact me by email if I can advise or assist you in any way.
            Larry
            37023
            • Larry Low
              Re: muncie 4 speed
              Larry
              37023
              • Loren L.
                • April 30, 1976
                • 4104
                Re: muncie 4 speed
                Replace it with a '65. Costs the same to rebuild and you end up with a more correct piece, plus the speedometer cable will reach the left side more easily.
                • Loren L.
                  • April 30, 1976
                  • 4104
                  Re: muncie 4 speed
                  • Larry Low
                    Re: muncie 4 speed
                    I agree. These cases are cheap and readily available. This would also eliminate any future cross matching of parts problems. For approximately $250+ you would be good to go with a like new Muncie, of course if you rebuild it yourself. Use your current tail housing.
                    Larry
                    • Larry Low
                      Re: muncie 4 speed
                      Larry
                      • Mike Arteaga
                        Re: muncie 4 speed
                        David: I just rebuilt my 67' muncie and found Paul at Medatronics to be a wealth of info and very willing to help!! They have case replacements and know these transmissions backwards and forwards. Their web site is www.gearzone.net! They also have a video on rebuilding that was invaluable!! Good luck!!! Mike Arteaga
                        • Mike Arteaga
                          Re: muncie 4 speed
