65 distributor 327/350 - NCRS Discussion Boards
  • Jimmy Roggenbuck
    I have a non origional distributor and it has a hole in the top part on the distributor on the drivers side under the cap.Was wondering if somethig goes there or is this for adjusting the points?
    I have been looking in catalogs and was wondering if the correct distributor is equipped with a vacuum advance of some sort.
  • Ed Jennings
    Re: 65 distributor 327/350
    Don't know about the hole right off hand, but the original distributer would have definately had a vacuum advance. All SB distributers for carb cars are interchangeable from 62-74. Advance may be calibrated a little differently on some models.
    • Ed Jennings
      • Jimmy Roggenbuck
        Re: 65 distributor 327/350 Thanks! *NM*
        • Jimmy Roggenbuck
