My 66 roadster has a rear differential cap with what looks to be a 5/8" square exposed end for unscrewing. The problem is I can't get enough clearance and leverage with a standard open end wrench to loosen it. Is there a square socket tool available to connect to a ratchet? Or, is there another way to go about this?
Midyear Differential Cap
Re: Midyear Differential Cap
Joe-----
Usually, a 12 point 3/4" socket will get the job done. If the plug is extraordinarily tight, seized, or rusted, the socket might slip on the square head plug. But, in most cases, it will work just fine.In Appreciation of John Hinckley- Top
Joe-----
Thanks for the advise guys. Joe, the 3/4 12 point wouldn't fit (too loose and slipped) and Wayne, the local tool guys looked at me like I was crazy. So, I did the only thing I could. I removed the spare tire and carrier and loosened the cap with a 5/8" box end wrench. It was a nice day anyway...- Top
