'67 Inner Trim Paint Question - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    Hi guys,
    I need to repaint the rear inner trim, the cover that covers the attaching points for the soft top on my 1967 convt. The color is supposed to be white. Should it be GLOSS? SEMI-GLOSS? SATIN? SEMI-FLAT? FLAT? As always, all help is greatly appreciated. Any suggestions as to which brand wouls do best?
    Don
  • Ed Jennings
    Re: '67 Inner Trim Paint Question
    It is definately not gloss or flat. I have seen just about everything in between. If I had to pick one of your definations, I'd probably lean toward "semi-gloss".
    • Ed Jennings
      • Donald O.
        • May 31, 1990
        • 1580
        Re: '67 Inner Trim Paint Question-Thanks *NM*
        • Donald O.
          • May 31, 1990
          • 1580
