59 BATTERY HOLD DOWN - NCRS Discussion Boards
  • BILL HARTER
    I JUST BOUGHT A BATTERY HOLD DOWN FROM CORVETTE CENTRAL,IT IS CAD PLATED. WERE THE ORIGINALS PAINTED? WHAT COLOR? THANKS BILL
    Re: 59 BATTERY HOLD DOWN
    Bill -
    Semi-gloss black.
      Bill -
      Semi-gloss black.
      • Ed Jennings
        John, I've got one of those gold colored ones too. Were the originals plated and then painted, or did CC just decide on their own to make them shiney?
        • Ed Jennings
            Ed -
            The originals were plain steel - the raw steel heat shield and hold-down were received separately and spot-welded together at St. Louis, then the assembly was washed, phosphated, and dip-primed (or flow-coated, same result). I assume the current repros are plated for corrosion resistance; I remember when I restored my '57 that the repro hold-down and the attached heat shield were plated - I primed and painted the unit black.
              Ed -
              • BILL HARTER
                THANKS ALL, BILL
                • BILL HARTER
                  THANKS ALL, BILL
