'62 Clutch Cross Shaft Rubber Bushing Install ?? - NCRS Discussion Boards
  • Denny Jacobs
    Simple question............Does the bushing get pressed into the lever from the engine side or from the outboard side? The piece left on the old shaft was pressed from the engine side, but from the other jury-rigged parts I've encountered on this car, I don't trust the previous mechanic(s) know-how. Thanks for the help.
  • James F.
    • December 1, 1985
    • 596
    Re: '62 Clutch Cross Shaft Rubber Bushing Install
    Denny,
    My '56 looks like it was pressed in from the engine side. Regards,
    • James F.
      • December 1, 1985
      • 596
      Denny,
      • Denny Jacobs
        Thanks Jim - Clutch Cross Shaft Rubber Bushing
        Jim,
        Thank you for the response. I am going to assume that some number of the viewers must agree with your answer since no one countered.
        Thanks again,
        Denny
        • Denny Jacobs
          Jim,
          Thanks again,
          Denny
