I purchased a 1961 GM NOS (?) fan shroud from a Driveline add. The shroud came with a GM sticker. The lower two-peice section fit very well. The upper section aligns and fits well with the lower two sections. The problem is that the holes used to mount the upper shroud to the radiator support assembly do not line up. Is this a common problem with after market shrouds, or was I sold the wrong shroud?
Thanks! Ray
Thanks! Ray
