cracked aluminum intake manifold - NCRS Discussion Boards
  • Steve Junkersfeld
    I started the 56 for the first time this morning. There's nothing like the gentle roll of the solid lifters and the sound of the exhaust to make all the headaches worthwhile. Speaking of headaches, I found a hairline crack in the aluminum intake. The crack is in the front coolant crossover on the passenger's side. Given that I would like to take the car to Bloomington, is welding a possible repair? Can a weld be ground down to "disappear"? The manifold is nice, other than the crack, but I think manifolds are around for a reasonable price. If anyone has had experience with cracked intakes, I would appreciate some advice. Steve
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: cracked aluminum intake manifold
    if it is a water leak a good epoxy inside the passage should do the trick. also if the crack is close to the opening it could be welded inside.
    • Clem Z.
      • January 1, 2006
      • 9427
        Steve -
        Try Jerry MacNeish at the link below - in addition to "re-skinning", he does incredible aluminum welding and repairs - some examples are on his website.
        Jerry MacNeish - Camaro Hi-Performance, Inc.
          Steve -
          • Steve Junkersfeld
            John,
            Thanks much. I emailed Jerry last night and heard back from him 30 minutes later! Since I live in the Wash DC area, I'm taking the manifold over to him tomorrow. Steve
            • Steve Junkersfeld
              John,
              • Verle R.
                • March 1, 1989
                • 1163
                John,
                Could you describe "reskinning" aluminum?
                Thank you,
                Verle Randolph
                • Verle R.
                  • March 1, 1989
                  • 1163
                  John,
                  Thank you,
                  Verle Randolph
                    Verle -
                    If I could, I'd go into business Actually, it's a "tumbling" process using proprietary media and chemicals that cleans the surface and allows the natural as-cast surface to oxidize again without destroying the surface texture. That's about all I know about it - the folks who do it aren't anxious to "share" the details of the process, for obvious reasons.
                      Verle -
