Ignition switch ground - NCRS Discussion Boards
  • steve hess
    While dinkin' around under the dash today on my '65 coupe I had to pull the ignition switch connector off the switch assembly. I noticed that there is no wire (or spade) going into the connector hole marked "GND". I could not find any stray wires under the dash. Is this option used?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Ignition switch ground
    Steve:
    Stop looking for missing wires, you shouldn't find any. The harness connector has room for a ground wire, but none is used. Possibly something relating to the ground distribution in a fiberglass bodied car. If I remember correctly, the connector has 6 slots, but only 5 are used.
    Joe
    • Joe C.
      • August 31, 1999
      • 4598
      Steve:
      Joe
      • steve hess
        Thank You! *NM*
        • steve hess
          Thank You! *NM*
          • Joe C.
            • August 31, 1999
            • 4598
            Addendum
            Steve:
            I looked over my ignition harness and need to make a correction. The harness connector has 5 slots, and only uses 4. The ignition switch has 5 terminals, and only uses 4.
            In any event, the "ground" terminal on your ignition switch is not used.
            Joe
            • Joe C.
              • August 31, 1999
              • 4598
              Addendum
              Steve:
              Joe
