Engine Identification - NCRS Discussion Boards
  • Don Tredoux
    Hi,
    I have a 72 Wagon, still trying to identify which kit it is, no
    side windows, the back window does not open, however Im looking
    for some help to identify and decode the number on my engine pad.
    : VO 89980 O
    (The "O" behind the V seems to be a the letter O not Zero,
    likewise the "O" at the end of the number.)
    I have the Casting number:
    : 14816379
    : Other numbers I found but dont know what they mean are
    : G99 and 48GM.
    : The Vin number is : 1Z67K2S508912,
    I have worked this lot out but it does not help,
    as I know the engine was replaced. (the K would mean Standard 72 motor)
    Any help would be appreciated.
    Many thanks
    Don Tredoux
    Re: Engine Identification
    Don -
    It's probaby 14316379, which was used for many different 350's from '69-'85 in trucks with a 2-piece rear seal, and in passenger cars from '78-'81.
      Don -
      • Don Tredoux
        Hi John,
        Thanks for this, I think you are right about the number. The "8" should be a 3.
        Is there any way that I can tell the HP rating etc of this engine?
        • Don Tredoux
          Hi John,
            Don -
            The pad stamp indicates that it's a service replacement engine, but I'm not aware of any way to decode it; a production engine would have a 4-digit number after the "V" to show the production date, followed by a 3-digit letter code which would identify the specific application.
              Don -
              • Don Tredoux
                Hi John
                Thank you very much for your efforts looks like a bit of a dead end.
                Thanks anyway.
                Best Don
                • Don Tredoux
                  Hi John
                  Thanks anyway.
                  Best Don
