'65-7 neutral safety switch for automatic - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    Has anyone found a reasonable source for new neutral safety switches for the '65-7 automatics? Reasonable = less than $50.
    I thought maybe a console safety switch from a '67 Caprice or Camaro (or something else) might be adaptable with a change in the wiring pigtail. Has anyone tried this approach?
    Re: '65-7 neutral safety switch for automatic
    Jerry -
    Just compared the C2 auto shifter photos/A.I.M. illustrations with the '67 Camaro shifter, and they appear to be very similar. '67 Camaro Powerglide neutral safety/backup light switches are available as new reproductions from Rick's First Generation (best 1st-Gen Camaro parts house out there) as their #SW-12 for $28.95; (800) 359-7717.
      Jerry -
      • Wayne W.
        • April 30, 1982
        • 3605
        I have done this many times with a switch available at any parts store. I actually put together an article on it but never submitted it. When I get to the shop I will get you the part number.
        • Wayne W.
          • April 30, 1982
          • 3605
          • Wayne W.
            • April 30, 1982
            • 3605
            NAPA Ecklin # NS 6172 You will have to switch the base plate with the old one and either solder or plug into the new part. Bend the terminals over for clearence.
            • Wayne W.
              • April 30, 1982
              • 3605
              • G B.
                • December 1, 1974
                • 1407
                Thank you both
                Thanks for pointing me in the right direction. I'm going to investigate both of the suggested switches.
                Wayne, I hope you do submit your switch article for publication in the Restorer. I think it would be appreciated by a lot of automatic owners.
                • G B.
                  • December 1, 1974
                  • 1407
                  Thank you both
