I recently had a close call where the driver side rear knockoff wheel loosened and and nearly came off the car. I caught it before a disaster, but the knockoff safety pin got chewed to pieces. Also the threads on the adapter for about 1/8 inch on either side of the semi-circular groove got slightly worn down from contact with the pin.
A few questions:
1. The undamaged pins look to be steel, but in the Long Island Corvette Supply catalog they refer to them as aluminum pins and the other catalogs I have don't specify the material. Does anyone know the correct material for the pins and where I can get them?
2. Is it safe to continue to use the adapter with the wear I've described?
3. I'd like to get a "correct" repro lead hammer that will pass NCRS judging. Any recommended vendors?
Thanks in advance,
Chris
A few questions:
Thanks in advance,
Chris
