Charging Voltage - NCRS Discussion Boards
Charging Voltage
  • Myles Kukurudz
    Charging Voltage
    Gents
    Just fired up my 67 427 for the first time after a body off and checking the vitals is 13.6 Volts at the battery good or should we see 14+ with the engine running, also is this adjustable ?
    Thanks Myles
  • Gary S.
    • July 31, 1992
    • 1628
    Re: Charging Voltage
    Myles, I will let the electrical wizards jump in here, but I have never been happy with a GM voltage that is less than 14.5. I am fairly certain that the 13.6 you are seeing is a tad low and that the GM tolerances for the voltage regulator should be higher.
    Gary
    • Gary S.
      • July 31, 1992
      • 1628
      Gary
      • Bill Clupper
        Remember to have the voltage regulator at full operating temperature before making the chack. Follow the prcedure in the service manual for checking and setting the regulator if necessary
        • Bill Clupper
          • Jack H.
            • April 1, 1990
            • 9906
            Couldn't have said it better, Culp! *NM*
            • Jack H.
              • April 1, 1990
              • 9906
              • Dave Henderson
                Your looking good, if it ain't broke dont fix it if you ask me.
                • Dave Henderson
