69 steel wheels - NCRS Discussion Boards
69 steel wheels
  • Richard Edgell
    69 steel wheels
    Would like to know the correct steel wheel code and the size? And tire size!!
  • Paul B.
    • April 30, 1995
    • 482
    Re: 69 steel wheels
    Richard, The steel wheels in '69 were coded "AZ" which are still available today. I think there is one small difference in that the original ones were welded and the new ones(still made by Kelsey-Hayes)are riveted or it may be visa-versa. Someone else here could probably elaborate. The original tire size was an F70-15. They were not radials.
      Re: 69 steel wheels
      Paul----
      Both the original and current-day "AZ" wheels are of welded construction. There are minor diferences in the modern wheels, but they are very slight. The wheels are available from GM under part #327708 or from independent Hayes Wheel dealers under Hayes #81982(NWRA #X-40317).
      • MIke G #33811
        Re: Door Sill Screws
        Don,
        I picked up the impact driver and it was great. It took a while and a lot more squirts of WD40, but I got all of them out without having to drill them out. I guess the thing I learned most is that patience and persistence is the key. Thanks for the recommendation.
        Mike.
        • Don O'Connell #33101
