64 Differential Lubricant - NCRS Discussion Boards
  • George D. #31849
    Can anyone explain to me how to change the differential lubricant on my 64.
  • Gary S.
    • July 31, 1992
    • 1628
    Re: 64 Differential Lubricant
    Go to your favorite auto parts store and buy a suction gun. Quite common and fairly inexpensive. Remove the differential plug and suck out your old lube. Use the same gun to fill the differential with new lube unless you buy the type of container that has the fill neck on the end, such as Mobil 1 Synthetic differential lube.
    It will help if you have just driven the car to warm up the lube and suspend any contaminants.
    Gary
    • Gary S.
      • July 31, 1992
      • 1628
      Gary
