Just bought 66 roadster the cast date code forward of the starter is very poor to read its # looked filled in. Here is the info eng casting 3869942 (427/390) body date ko8 (june 8th) vin 6124456 (end of june but do not know day) eng pad looks proper to my eye vin match eng# T0609IL (427/390 manual june 9th)Cast date on block best guess F76 (june 7th 66)it appears to have a soild circle first then the f the 7 is best seen and the 6 is poor and after the 6 looks like another # or another filled circle
Does any one know the asy date from the above?
Does theys dates fall inline with NCRS guidelines?
What should I do about the cast date? should I take a wire brush to them? I cleaned some paint off them but stopped as I did not want to make it worse.
Is it possible that the last casting left material and bonded to my engine? is this common?
Thanks and scared it might not be orq.
Mike
Mike
