66 headlight motor runs in the down direction only - NCRS Discussion Boards
  • darwin kuhlmann
    Hi,
    I have taken my headlight motor out which only runs in the down direction. It was working, but has not worked well in the up direction for a while. The gears turn and I could manually rotate the lights up. On the bench the motor runs only down ( power put on each contact prong one at a time ). Before I attempt to take the motor apart, what should I be looking for electronically. Bad bushings, contacts etc.?
    Thanks, Darwin
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66 headlight motor runs in the down direction
    If it doesnt even try to work, I would look for a broken wire near the contact.
    • Wayne W.
      • April 30, 1982
      • 3605
