Hi all,
In my 67 convt L79, no a/c, no PW, with all the fuses in their circuits, I removed all three connections on the alternator and my ammeter read 0.00 amps. Reconnected the black ground lead and still no short. Reconected the plug-in connector (Dark Blue wire and White wires that go to the voltage regulator) and the short returned, 1.37 amps. Disconnected the connector again and the short went away. Reconnected the red lead (back to battery) and again no short.
How can I check the voltage regulator, it is an aftermarket solid state type.
Is the problem in the alternator itself and how do I check it? TIA
Don
Don
