Door Hinge Pin Orientation on a 65 Roadster - NCRS Discussion Boards
  • Floyd Dossey
    I am replacing the door hinge pin and bushings on my 65 roadster,
    when I checked the hinge pins,the upper and lower pins were
    installed different on each door.What is the CORRECT hinge pin orientation??
    ie. do both pins START from the top of the hinge down, inside to the outside, bottom to the top?? Thanks.
    Floyd
    65 FI
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Door Hinge Pin Orientation on a 65 Roadster
    Floyd,
    The hinge pins should always point down. Left or right doors, upper or lower hinge.
    Don
    • Donald O.
      • May 31, 1990
      • 1580
      Floyd,
      Don
      • Floyd Dossey
        Don,
        You have been a big help.
        Floyd
        • Floyd Dossey
          Don,
          Floyd
