Pitman arm seal? - NCRS Discussion Boards
Pitman arm seal?
  • Mike Arteaga
    Pitman arm seal?
    I'm rebuilding the steering box on my 67' L79 and I didn't take good enough notes when disassembling! Althought I'm not sure it was right in the first place since it was leaking like hell! I'm about to place the pitman arm seal into the housing and I'm not sure which way to place it. It dosen't look like the normal seal so I'm not sure which way to place it! One side is flat but has the outer ring showing plus separate inner rubber ring. The other side has the outer ring and an inner protruding rubber sleeve. After all the work I'd prefer to get it right!! I'd appreciate any help!! Mike Arteaga
