54 Engine Origin ? - NCRS Discussion Boards
54 Engine Origin ?
  • John Spencer
    54 Engine Origin ?
    I am restoreing a 54. My Engine is a correct casting 3835911 but the stamp is foreign to me. Instead of the F54YG it is F54X. The serial number is also unusually high 1009532. My car's S/N is E54S003034. Any ideas on what these number mean ? Or info. as to it's origin would be appreciated.
    Re: 54 Engine Origin ?
    John-----
    The GM #3835911 casting was used for other applications besides Corvette. So, I expect that the "X" suffix code denotes one of them. At the moment, I can't tell you what the "X" suffix code was used for, but I may be able to later.
      John-----
      • John Spencer
        Joe L - thank you for your response. I suspect the engine might be a replacement. The head is 3835911, but everything else is correct - carbs - manifolds - dist. / fuel pump / oil pan. Let me know if you run across any additinal info.
        • John Spencer
          • Chuck G.
            • May 31, 1982
            • 2029
            I belive the "X" is for half ton pick-up trucks. The 911 is/was the HD block and was not used exclusively in Corvettes. What's the casting date....located above the starter? Also, the head should be 241...not 911. Chuck
            • Chuck G.
              • May 31, 1982
              • 2029
