Hockey Sticks
  • Mike Andresen
    #1
    Hockey Sticks
    My 66 hockey sticks need to be either rechromed or replaced. Any suggestions on whether replating is a good cost effective option or should I just buy new?
    Cheers
    Mike
    #27410
    • 42936
    Re: Hockey Sticks
    Mike-----
    Rechroming is not inexpensive. However, if the parts are otherwise in good shape and you can find a high quality plater, I would always opt for rechroming. That way, you have original parts and, very likely, much higher quality chroming than you will otherwise obtain with new parts.
      • 42936
      Re: Hockey Sticks
      Mike-----
      • Mike Andresen
        Rechroming Recommendations In Lafayette IN
        Thanks Joe. I'm always honored when I get a response from you. A sincer thanks.
        Any suggestions out there of a quality chrome plating outfit in or around Lafayette Indiana?
        cheers
        Mike
        #27410
        • Mike Andresen
          cheers
          Mike
          #27410
          • Jim T.
            • March 1, 1993
            • 5351
            Re: Rechroming Recommendations In Lafayette IN
            Mike in the Driveline you can usually find an add for a facility in TN I think it was Arebia. I have not had anything chromed in years but I had seen a post before where Arebia was recommended. I seem to remember seeing some of their work at a Knoxville Expo once and it looked really good.
            • Jim T.
              • March 1, 1993
              • 5351
              • Brandon K.
                • April 1, 1997
                • 15
                I had tried calling Areba a while back and never could get through. I seem to recall leaving messages that never got returned. Hopefully you'll have better luck.
                BK
                • Brandon K.
                  • April 1, 1997
                  • 15
                  BK
                  • kenrobb
                    Re: Hockey Sticks
                    I had mine done by Bison Plating in Adell, Wis. 920-994-4013. good service then in 1998. Think it was $25 each then.
                    • kenrobb
                      Re: Hockey Sticks
                      • Brandon K.
                        • April 1, 1997
                        • 15
                        Bison plating
                        Just got off the phone with Bison and they're only doing powder coating now-- no chrome plating.
                        • Brandon K.
                          • April 1, 1997
                          • 15
                          Bison plating
