Hello all.....
Looking for the best spark plug to use on my L79. I have rebuilt using flat top pistons and comp cams extreme energy cam with specs similar to the original. Will probably go with AC plugs, but what heat range? Should I stay with stock plug or does the compression change mandate a different one? Thanks!!Brandon.
