My 65 small block, 327/250 is still having a real problem. It will only run at higher rpm. It continues to feel as though it is missing even at higher rpm. The carb was just rebuilt with no positve effect. It has a new distributor, I just set the dwell to 28(spec is 28-32). The timing, vacuum advance were previously set and the car worked fine. It has set for the majority of 2 years. The gasoline is of varying vintage. New plug wires, plugs. At cranking it will occasionally backfire and shoot white smoke out of the carb. Any educated ideas? Thanks for your inputs.
Rick
Rick
