casting date on '65 m/c - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    Can anyone advise the significance of the "239" on the bottom of my '65 standard master cylinder. It's casting number is 2225032. Is the 239 a date? Are these m/c dated? Thanks.
    Re: casting date on '65 m/c
    Mark-----
    These master cylinders were manufactured by Bendix and the casting number is a Bendix number, not a GM number. As far as I know, these units were not dated. If they were, they used a system which was unlike that used on GM-cast components. However, I do not think that the "239" is a date, but I don't know what its significance is.
      Mark-----
      • Mark F.
        • March 1, 2002
        • 174
        Thanks (again), Joe NM *NM*
        • Mark F.
          • March 1, 2002
          • 174
          • Wayne M.
            • March 1, 1980
            • 6414
            Mark --- I'm not convinced that these are NOT Julian calendar dates; I've never seen one over 365. Does your car's production date follow the end of August M/C date (if Julian) ?
            • Wayne M.
              • March 1, 1980
              • 6414
              • Mark F.
                • March 1, 2002
                • 174
                Indeed it does, Wayne. The AO Smith build date is August 27. I've calculated the car's assembly date to be Friday, Sept. 4, 1964, which is Julian date 247. The m/c number of 239 appears to be a right Julian date for this car.
                The m/c is leaking badly, needing a brass sleeve. I was thinking of buying an already rebuilt one and using mine as a core. NOT ANY MORE!
                My money's on your opinion, Wayne. Thanks.
                • Mark F.
                  • March 1, 2002
                  • 174
