C3 Master Cylinder & Starter Rebuild? - NCRS Discussion Boards
  • Jeph South
    70 LT1
    I'm set up with Arthur Gould for the water pump, but does anyone have a recommendation for the starter (1108338) and the master cylinder (5455509)?
    And while I'm at it, I still can not locate the proper choke for my Holley 4555, if anyone has a suggestion on where else to look for one I would appreciate it.
    Thanks in advance,
    Jeph
  • Brian M.
    • February 1, 1997
    • 1837
    Re: C3 Master Cylinder & Starter Rebuild?
    Talk to John Pirkle about the starter PH# 706 860-9047. Billy Thompson of White Post Restorations for the master cylinder PH# 540 837-1140 Good Luck
    • Brian M.
      • February 1, 1997
      • 1837
        Jeph-----
        For the master cylinder: White Post Restorations (www.whitepost.com) or Apple Hydraulics (www.applehydraulics.com).
        For the starter: John Pirkle. His is e-mail address is/was pirklesr@juno.com
        The Holley 4555 uses a divorced-style choke. If what you need is the thermostatic coil, you can order one from any GM dealer under GM #3887148 for a GM list price of $12.66. If you need some other part of the choke, post what you're after.
          Jeph-----
          • Jeph South
            Joe,
            I really don't know what I need. I think I remember seeing one as the coil in a housing sitting in the well of the intake with a pushrod for the butterfly. If the part number you provided is the coil and housing, I can modify a pushrod. Part of my problem is that I don't know exactly what to ask for. The service Holley I was using (3310-1) has an electric choke and my 4555 does not have a choke at all. So I am looking for everything up to the butterfly.
            • Jeph South
              Joe,
              • Mark Ring
                I recieved a master cylinder back from Apple Hydraulics earlier this week and it looked great. Cost was around $80 or so. I had them put a brass sleeve in the bore and they cleaned it up real well with a fast turnaround. I would shop there again.
                -Mark.
                • Mark Ring
                  -Mark.
