Rag joint - NCRS Discussion Boards
Rag joint
  • Eric fairclo
    Rag joint
    How can you tell if a rag joint is bad?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Rag joint
    It looks rag-ged?
    1)Physical deterioration of the rubber and cloth sandwich
    2)Differential in movement between the upper and lower halves while the steering wheel is being turned.
    • Michael W.
      • April 1, 1997
      • 4290
      Re: Rag joint
      It looks rag-ged?
      • Myles Kukurudz
        Re: Rag joint
        If you watch the rag joint very carefully while someone inside the car is gently moving the steering wheel left to right you may notice the studs in the rubber are elongated and there is play in the assy
        • Myles Kukurudz
          Re: Rag joint
