No exhuast manifold gaskets 70 LS-5 - NCRS Discussion Boards
  • Thad L.
    • April 30, 1999
    • 168
    Ok, the heads are clean and I just got the manifolds back from getting a surface job! Now is there any secret or trick to getting the manifolds to seal against the heads? I have done this before with pretty good luck but want this car to be right and have no leaks like when new! Thanks to all for all of the help in the past and future! Thad LeJeune 32187
    Re: No exhuast manifold gaskets 70 LS-5
    Thad-----
    I think that you've done all it takes to achieve a perfect seal. Just bolt them on, torque to specifications and I think you'll find that you'll have no leak problems, whatsoever.
      Thad-----
