66 BB fan shroud - NCRS Discussion Boards
66 BB fan shroud
  • Barry Mills
    66 BB fan shroud
    The third edition of the 1966 NCRS Judging Guide indicates on page 105 that the three pieces of a non-AC big block fan shroud are glued and have a single rivet at the upper left hand joint. Page F202 of the Assembly Guide has no reference to the rivet and an owner of a well known fiberglass reproducer has mentioned to me that there never has been a rivet on the 66 BB fan shroud. Any guidance on who may be correct?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66 BB fan shroud
    In general there are no rivits, however ocasionally you may see one that was factory installed.
    • Wayne W.
      • April 30, 1982
      • 3605
      • Dan Pepper
        Barry,
        The original fan shround that came on my '66 BB AC coupe had a aluminum plug type rivet through the top seam. The shroud was broken, although I salvaged the rivet and "reinstalled" in on a repro fan shroud (with extension ring). THe car was judged, and no points deducted for the shroud. The repro from LICorvette was pretty good, although I spent 4 or 5 hours cutting the extension ring slots, adding the rivet and in general, making it look like the original fit and finish.
        Dan
        • Dan Pepper
          Barry,
          Dan
          • Peter M.
            • February 1, 1984
            • 361
            Barry - My 66 BB Fan Shroud (early April production) is original and has no rivet.
            • Peter M.
              • February 1, 1984
              • 361
              • Pete Lovrovich
                My 66 big block (Nov 65) has the orginal fan shroud and it has a rivet.
                • Pete Lovrovich
