The sending unit in the bottom of the tank has two wire terminals and a ground terminal. The two wire terminals are marked "S" for sender and "I" for ignition, I'm guessing.
Which wire, pink or tan, is connected to which terminal?
If they were connected wrong and the ignition turned on, could that cause the guage in the instrument panel not to function or be damaged? Thanks for the help.
