I have a '59 I just purchased and on the way home I discovered that the battery wasn't being charged. I removed the generator and voltage regulator and had them tested. The voltage regulator supposedly checked out OK. The generator did not. I replaced the brushes in the generator, cleaned all connections and reinstalled. The amp gauge still shows no charge. I am assuming the gauge is working since it shows a draw when the starter is engaged.
The battery tested OK.
Should I go ahead and bite the bullet for a new generator or are their additional procedures I should perform? Any advice is greatly appreciated.
