C1 Clutch cross shaft frame bracket - NCRS Discussion Boards
  • Clark McEwen
    I am working on a 1959 frame that the previous owner had butchered.
    (1) What are the measurements for the correct placement of the cross shaft and clutch return spring brackets on the frame?
    (2) What is the length of the correct cross shaft bracket that bolts to the bellhousing?
    (3) For some reason the brackets that hold the motor mounts to the frame have been moved, what is the correct placement of these brackets?
    (4) Is there a detailed schematic of the frame with the bracket placements available?
    Thank you in advance
    Clark
  • Gary Chesnut
    Re: C1 Clutch cross shaft frame bracket
    Might have templates for motor mounts for a 57, should be same, will check tonight and let you know. Gary.... e-mail: gchesnut@flash.net
    • Gary Chesnut
