Thermostat operation - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    #31
    Re: alcohol anti freeze story
    Cold start methods brings to mind of when the 6 volt battery system would not start my Dad's old 49 Plymouth it was common to hand crank the Allis-Chambers tractor, get it started, put water in it, pull the Plymouth and get it started. Shut down the tractor and open the block and radiator drain cocks and let the water drain out. Learned real quick about kick back in hand cranking that tractor on cold mornings.
