Well, just when you thought you were finally there.....! The new engine is in the 66 427/390. It started right up. After a few minutes of running, there was a very high pitch whistling sound coming from the back of the block. I have been told that this is an indication of a bad main bearing, however this engine was supposedly REBUILT by Performance Engines out of Nebraska. Please say it isn't so!!!!
Does anyone out there have any insight as to what other problem it could possibly be. It would be great if it were something simple?????? I have had good luck with Performance Engines up to this point and since I did pay quite a bit of money for this rebuild, I find it hard to believe the main bearing could be the problem. Maybe I am still to naive!!!!
As always, your assistance is always greatly appreciated.
Thanks alot.
Deb
Thanks alot.
Deb
